250ED rear shocks
Bobv07662
250ED rear shocks
Post by Bobv07662 »
Anyone have a recommendation for someone who can rebuild the rear shocks for my 250ED? They don't need any chrome work or polishing. Damper valves and shaft seals should do it.
250ED
250ED
Thanks, Bob V.
1976 ED250
Re: 250ED rear shocks
Bob! Where are you located? There might be someone close by who can help you! :ugeek: Victor
Bobv07662
Post by Bobv07662 »
Victor, the Thunderdog and I call northern New Jersey home.
1976 ED250
I was born in Paterson but left NJ when I was 4! I’ve been in NM since 1975! :ugeek: Victor
I can summarize the work of Hodaka Dave Rozier (Hodaka Dave's Vintage Service) in one word - superb.
Bobv07662
Post by Bobv07662 »
Thanks for the Hodaka Dave recomendation matt, I will contact him.
Small world Victor, I was born in Paterson as well. Do you remember the Hodaka dealer in Hawthorne that also sold Datsuns, Alphas and Lotus? That's where I bought my first Hodaka. (O'Brien's Datsun). A 100B+ then a SR.
1976 ED250
Like I said, I left Paterson when I was 4 years old. I remember the Paterson Bakery, St. Anthony’s and the drug store. That’s about it. I agree with Matt on the Hodaka Dave recommendation! Here is Dave Rosier’s phone number : (573) 834-5001 :ugeek: Victor
If you are a member of the Hodaka Club, I wrote an article on how to rebuild the shocks from a model 97/98 Super Combat/Super Rat. The shocks are basically the same as the 250ED shocks, so the rebuild should be the same. The article is in the last issue of the Resonator Revisited.
Bobv07662
Post by Bobv07662 »
Thanks David, that info is just what I needed. I ordered 2 kits and will report back with the results.
Bob V.
1976 ED250
Bobv07662
Post by Bobv07662 »
Reporting in on the rebuild.
Dave's article in the Resonator provided the part number and vendor for everything I needed to rebuild the shocks. The 8 1/4" length kit is no longer available but the 8 inch one did provide enough pieces to complete the job. I used the rubber jounce bumper, the entire screw in cap-wiper-seal assembly, top o-ring and a few assorted valve discs. All for $8 per shock. Dave noted that the kit damper valve is a larger size and won't fit in our KYB damper tube but mine was quite serviceable with the use of some of the new valve discs. I also used 100cc of ATF to fill the shock. Just keep in mind the valve stack up consists of quite a few pieces so you should pay close attention when you disassemble the valves.
1976 ED250
Good to hear that all went well. Thanks for the feedback.
Dirty_rat
