My Super Rat has early Penton 32mm Ceriani forks. I am changing the oil but have lost my notes. How much oil do I add to each leg? I did a search on the Penton Group and the answers were all over the place. Some say 135 cc, some say 200 cc, some say springs out, forks collapsed ,6" from top. Help!
Larry S
Fork oil queston - 32mm Cerianis
Re: Fork oil queston - 32mm Cerianis
The amount I’m seeing is 270ml per fork tube. I have the same forks on a Wombat frame with a Super Rat motor & pipe. I call it my Super Squirt!
270 Milliliters (mL) = 9.12979 Ounces (fl oz)
Best I can do at this point! Victor
but 9 ounces and 78 drops would probably be close enough, depending on how many drops you let drip out of the bottle. Henery L kinzington
“...and 78 drops....”. Good one Clarence!!! Victor
