03 patina build
Re: 03 patina build
Um...we all did Pop :)
Re: 03 patina build
ive read this on this forum ......Sometime you can make extra thick fiber plates, by carefully sanding off one side of two plates, making them into one thick plate. This is a great use for plates that are knackered on only one side. One clutch I use has two pairs of fibers done this way. As long as there is a steel against the stamped cover, and the gap is correct, the clutch should release and hold without slipping.....so i guess your only stopped by your own imagination
Re: 03 patina build
ossa95d wrote: Wed Nov 18, 2020 6:54 am The schematic for the 03 shows 5 steel and 4 fiber. That's probably why the rebuild kit had that configuration. I'm just trying to make sure to keep everyone confused.
Check the sequence shown in the schematic too. Not what one might assume.
Re: 03 patina build
Yes the 03 Wombat clutch is not like the typical earlier configurations found in other Wombats. :ugeek: Victor
Re: 03 patina build
couldn't help my self, i now have another 03 with the two i should be 99 % whole bike. lots of parts that the first one was missing. haven't had a chance to look to close seems fairly ok over all
Re: 03 patina build
That looks like a very nice start to a great bike. I had seen this bike listed and wondered where it might end up. Nice work!
Re: 03 patina build
Watch out Pop, they’re multiplying!!! :ugeek: Bictor
Re: 03 patina build
Watch out Pop, they’re multiplying!!! :ugeek: Victor
Re: 03 patina build
yeah victor 5 hodaka's 8 bikes total , 1 mini bike project, 1 go-cart, wood projects the shop is bursting at the seams. wouldn't have it any other way. ddvorak it has the possibility to be a nice one with the parts i had and whats on this one it should work out fine . im still going for the patina look ......albert
Re: 03 patina build
little up date . my new friend, the old hodaka dealer in town , came over and we started to put the motor togeather so were cleaning it up , which i thought was very clean already , tells you how much i know, we were working on it for a while and he says you know we should really get this bead blasted to clean it up good and the guy who bored the cylinder out just happens to have one so the patina build might need a new name. he took the parts and got them back today. wow what do you say, they look great. uh well i asked how much or what could i do for him and the guy who blasted them and he said nothing he had a good time hanging out in the shop and he had to sweep the floor. im kinda over whelmed with it all right now but will make it right. when he has the time we will finish putting the motor together. the photo with the shifter cover laying on it shows how much better the parts look
Re: 03 patina build
the muffler on one of my 03 wombats has some issues. how do you get the end that goes on to the motor off of the pipe. im sure i can do it just thought there might be a trick to it thanks ...albert
Re: 03 patina build
Cut it with a grinder. :ugeek: Victor
Re: 03 patina build
No, no grinder. Break out the propane torch. The exhaust manifold is aluminum, when heated it will expand more than the steel pipe. With a standard home style propane torch, you would have to work awfully hard to over heat the manifold. So heat it up then tap it off with wood block and a hammer. You might want a buddy to pin the pipe to the ground for the tapping operation. I recommend a cold Porter, a glass of nice rose', or a shot of Yukon Jack for post-manifoldectomy toasts with a friend. (or all three???)
Re: 03 patina build
You want to save the exhaust manifold? Then the Captain’s way will work best. Also, if you wrap a cool wet towel around the pipe it will heat up less. :ugeek: Victor
Re: 03 patina build
gave it a go and needs a few heat cycles ran out of time and my helpers 12 so i will forgo the clinking of glasses might spring for dinner with a soda pop thanks for the help....albert and elliot
Re: 03 patina build
Several heat cycles will surely help - and your favorite penetrating oil too. Large channel-lock pliers and twisting action could also be good - but take care to 1) not crush the manifold or 2) leave a bunch of plier tooth marks.
PS: Coke or Pepsi?
Re: 03 patina build
dr pepper..... heres what it looks like cleaned up. thats all i could save
Re: 03 patina build
and here's how it looks now . time to find a sand blaster
Re: 03 patina build
oops
Re: 03 patina build
Starting a new build??? 😉 Victor
Re: 03 patina build
Wow!!! Is that the same exhaust manifold??? 😵😲😮!!! :ugeek: Victor
Re: 03 patina build
Hey Albert. If you need a pipe to replace that, I can help you out! Is the silencer section still good? 😉 Victor
Re: 03 patina build
well victor as you might know a while back i dragged ,quite literally, a 03 wombat home that i was going to just get running leave as original as possible, but once i got in to it i found that there were rust issues and lots of missing parts so i picked up another 03 that had parts that i needed , so im making one street legal , and one dirt. as for the pipes i now have two pipes that i can make work. and the header and spark arrester end were to good to not clean up for the future .we will see what develops.....albert
Re: 03 patina build
Albert. 👍👍👍 :ugeek: Victor
Re: 03 patina build
sand blaster today, friend got it done . got my painter to come over to get some primer on, nice step forward
