Kick stand holder
Kick stand holder
It looks like someone cut the kick stand holder off the Wombat I just bought. Does anyone have this piece lying loose around there shop or have a bad frame with one which could be cut off?
This is the piece I mean. And it was cut off about where I drew the yellow line.
If you have one you can spare, please let me know! Thanks in advance! Victor
- Attachments
- BBE459B7-5E52-494D-95F1-2E3B8923B686.jpeg (25.19 KiB) Viewed 1574 times
Re: Kick stand holder
That would be absolutely great! I await your confirmation!!! Victor
Whatever you can send me. I need at least one. I’d also like to put one on my SC frame. I’ll PM you my mailing address! Victor
Thrown. You have a PM!!! Victor
Thrown. I sent you a second PM. Please read it & reply! Thanks! Victor
Thank you Dan! PayPal sent! Merry Christmas!!! Victor
Theyll go out Monday.
Thank you Sir! Merry Christmas!!!
I went and looked at the Ace 90 I just bought & it’s missing the kickstand mount also. So sending me 2 was a great idea! Thanks again! Victor
VIC,
I would just make one from a piece of "Angle Iron".
Just drill a hole, cut and file it, then you could even Heat Treat it.
Moxie 1944
Rick, Not a bad idea, if I can find thick enough angle iron. But Dan is sending me a couple from some cut up frames he has! Victor
Well, knowing that I had a need, and knowing I wasn’t the only one who likely needed kick stand mounts to weld onto frames, I arranged to have one copied and had 10 new ones made!
They are all ready to weld onto your frame! I’ve had 10 made, Snd will make more as needed. I’ve already sold 2! If you need a kick stand mount contact me via private message or by email! Victor
