What would be a fair price to ask for my 1971 Custom Hodaka "Trials"?
Custom Built Hodaka “Trials” Motorcycle
Built by Chris Miller.
This Motorcycle was Built on a Modified 93A, 1971, Super Rat Frame.
The Engine is a Rebuilt 01 Dirt Squirt 100 cc with Reed Valve.
Only Ridden at “Hodaka Days” for 6 years Since Built.
Comes with New Mexico “Clear Title”, is Currently O. H. Tagged to 07/2021
The list of Components and Modifications.
Frame:
Head Angle Decreased to Trials Specifications with New Stronger Welded Gussets.
Swing Arm Lengthened and Reinforced.
Rear Shock Mount Moved Forward to Accommodate Additional Length.
All Sand Blasted and Powder Coated in a Gloss Black Hammered Finish.
Skid Plate
Engine:
Complete Rebuilt Low End, Top End, All New Bearings, Seals, and Gaskets
New Shift Kit
Carb Rebuilt
Rebuilt 5 speed Transmission
Additional Weighted Flywheel for Improved Low RPM
Custom Tuned Exhaust with “Pro Circuit” Muffler / Forestry Approved Spark Arrester
Custom Spun Aluminum Air Filter Canister, K&N Filter, and Fabricated Filter Holder / Bracket.
Blocked Off Oil Injection System (Uses Gas / Oil Mix)
Compression Release Mounted in the Head.
Wheels:
Front 2.75 x 21 “Dunlap Trials” Tire on a “Takasago Excel” Alloy Rim with “Buchanan” Stainless Steel HD spokes. With Rim Lock
Rear 4.00 x 18 “Michelin Competition Trial” Tire on a “Takasago Excel” Alloy Rim with “Buchanan” Stainless Steel HD spokes. With Rim Lock
Front and Rear End Suspension:
Stock Hodaka Super Rat Front Forks Rebuilt with New Seals and Boots.
“Betor Competition Trials” Rear Shocks
Handle Bars:
“Sammy Miller Renthal” Blue Alloy Competition Bars
All Cables, New
Compression Release Lever
Drive:
“Sprocket Specialties” 70 tooth Rear Alloy Sprocket
New 13 tooth Primary Sprocket
New HD .428 Chain
Automatic Chain Tensioner
Rear Mounted Reverse Pattern Shifter (1 down, 4 Up)
Other:
(The Following Custom Fabricated Components)
Wider, Spring Loaded Foot Pegs
Custom Seat Pan, Foam and Cover
Narrow “D.T.” One Gallon Fuel Tank
Fiberglass Front Fender, Mud Flap, and Powder Coated Mount Bracket
Number Plate
Gloss Orange Paint on Both Fenders and Pin Stripping.
Renforced Kick Stand
Frame:
Skid Plate
Engine:
New Shift Kit
Carb Rebuilt
Wheels:
Handle Bars:
All Cables, New
Drive:
New HD .428 Chain
Other:
Number Plate
Moxie 1944
Re: What would be a fair price to ask for my 1971 Custom Hodaka "Trials"?
Where in NM are you located? I’m in Santa Fe! Victor
What major town are you close to or E, W. N, South side of the state What do you think you would want and how long could you hold it? --------------- Clarence
I'm sorry if my post sounded like I was trying to sell my Hodaka Custom Trials Motorcycle on this Forum.
I was Not that is why I didn't mention the Price or my location and contact.
I have been trying to sell it here in Grants, New Mexico with no Bites!
Victor, check Albqu Cregs list.
Clarence, I can not answer anything more so that I don't cross any lines with the forum.
I was just wanting to know what the "Learned Members" felt this Hodaka was worth, Not trying to sell it on the Forum.
Again, I am sorry if I crossed the Line here.
Moxie 1944
What would you have to get out of it to make selling it worth the effort? Then go from that point.
I looked at your CL ad, that’s a fair price but it is a “specialty “ bike. So your market is slightly narrow.
What a beautiful Hodaka. To me you never broke any rule. you asked, what would be a fair price. Then you politely told us where to look. you could not have been more professional. I looked up Albqu and I think your price is very reasonable. If anybody crossed the line it was I --------Clarence
Yes, it is a Specialty Built (Trials) motorcycle but if you change the Seat, and Final Drive Sprocket it will make a Great Dirt Bike too.
I have a 36 tooth and another BMI seat too.
Moxie 1944
An interesting bike. I think we visited at HD 19. How do I contact you. Bruce
Check the Albuquerque Cregs Listing
Moxie 1944
Great looking build. I see you have also found BMI Karts, that's where I found rebuild kits for the Super Combat shocks.
Just a quick question. With the shift lever turned backwards, wouldn't that make the shift pattern 1 up and 4 down?
Yes, but like other MCs you get use to it.
Moxie 1944
Rick! It was nice meeting you today!!! I felt like I have really made a new friend!
I think you should stick to your guns on the price! Especially after showing me your “Binder!” I’ve never seen a bike that well documented! Stick with advertising on Trials forum & trials websites! I’m sure you’ll find a buyer! And I think you should start at $6,000 & negotiate from there, Not from $2700! Victor
