35w Stanley headlight 5-3/4
Adrenalinejunky
Post by Adrenalinejunky »
I searched and read every thread that came up.
Anything new for later model 35w head light replacement? Sorry if I missed something. These are obsolete now?
Re: 35w Stanley headlight 5-3/4
There’s a member here who sells the Stanley replacement headlights. But, I can’t remember his name! I bought 2 from him. :ugeek: Victor
MTrob??
rlkarren
Post by rlkarren »
if you wish to make a nearly undetectable mod to your trim ring, you can use the lens/reflector from a Honda CT90/100/110. Then, you can purchase 6v 35/35w bulbs at dratv.com. You can also use the Octane Lighting lens reflector and use halogen bulbs which are also available from Octane Lighting.
I use the octane lighting bulb in my Wombat and the repro CT lens in my Ace 90.
$0.02
Adrenalinejunky
rlkarren wrote: Tue Aug 04, 2020 10:26 pm if you wish to make a nearly undetectable mod to your trim ring, you can use the lens/reflector from a Honda CT90/100/110. Then, you can purchase 6v 35/35w bulbs at dratv.com. You can also use the Octane Lighting lens reflector and use halogen bulbs which are also available from Octane Lighting.
$0.02
Thanks. The ct90 is same diameter?
