Attaching Mag Cover
Ace100B
Attaching Mag Cover
Post by Ace100B »
Hi all,
Does anyone know of to properly re-attach the mag cover?
See pictures:
1.
2.
Re: Attaching Mag Cover
You’re missing the shifter case dust seal, which goes around that hole. You can order them from Terry Larson at Hodaka-Parts.com
Then there are 3 bolts which hold the mag cover on. You also need to remove the inspection cover on the back of the mag cover in order to line up the control shaft with the shifter sliding pin & make sure the sliding pin is between the 2 rings on the end of the control shaft. Then tighten the 3 case screws and re-install the inspection window cover. :ugeek: Victor
http://hodaka-parts.com/item.asp?cID=0&PID=1699
Ace100B
Post by Ace100B »
Isnt that dust seal you speak of around the hole already??
Al Harpster
Post by Al Harpster »
I think that's what's left of the dust seal. It looks beyond worn out.
BUT... it is a bit of a pain to put the mag cover back on.
In brief, the shift shaft has to be in the "same gear" as the foot selector mechanism.
If the foot selected is in 4th and the shaft is nestled in 1st it ain't gonna line up.
AND for initial test to see if everything is working the dust seal can wait a bit.
But you'll need to pull the cover again to install a good one.
Ace100B
Post by Ace100B »
well wouldn't I have pulled off the mag cover with the shift in neutral? how do I make sure they are lined up?
What is the shift shaft? Sorry for all the questions.
That thing you have the arrow pointing to is the shift shaft. Take off the small inspection cover to so you can see the shifter pin into the groove on the shaft. You can move the shift lever if needed to get it the right position. You do know the shift pattern for the case you have?
Ace100b, where do you live? Someone could come by your place and school you on a lot of things you should know by showing them to you on your bike.
