Banjo Bolt?
toadroad88
Banjo Bolt?
Post by toadroad88 »
Hey guys, did the oil pump delete on a model 02 road toad. Wondering if anyone knows the size / threads for the banjo bolt that goes into the intake? I want to blank that off as well. It’s part 993721 in the manual for reference. Thanks!
Re: Banjo Bolt?
I believe it’s a 6mm or maybe a 5mm? I’d have to go check. :ugeek: Victor
toadroad88
Re: Banjo Bolt?
I need a caliper to check these myself I know! Bike repair cost to get it decent: $300. Tool cost to repair bike. $300. Haha!
I need to track down that screw, and some plastic plugs for the holes where the grommets were and I’ll have most of the easy stuff done.
Re: Banjo Bolt?
Get one of each next time you're by an Ace Hardware and you'll get change back from a quarter. The good thing about investing in good tools is that they'll last a lifetime and you'll use them again and again.
Re: Banjo Bolt?
I pulled mine out and checked. It’s 6mm x 1.0 thread pitch and maybe 10mm long. :ugeek; Victor
P.S. And now I dropped it and will have to move 4 bikes just to find it and screw it back in! LOLOL!!!
