Wombat internal fork tubes
Dennis D
Post by Dennis D »
Disassembled the fork tubes on the Wombat today and found both of what I call the dampning tubes broken. Is this a common problem with these forks, something I need to look for, or am I just lucky, again...... Thanks, D
Re: Wombat internal fork tubes
It seems like you'd have to remove the damper rods, break 'em, then put 'em back in the forks.
What is broken on the damper rods? (and no, I don't remember ever seeing "broken" damper rods)
A picture is worth a thousand words. Lets see what you've got.
href="http://youtu.be/3EUbKp8j09M">youtu.be/3EUbKp8j09M
Stever
Post by Stever »
" What is broken on the damper rods? (and no, I don't remember ever seeing "broken" damper rods) Ed "
When you think you've seen most everything, something like this comes along. And not one rod but both, so it is not a freak manufacturing defect. I'm anxious for a picture so the detective work can start!
Stever
Dennis D
Post by Dennis D »
If I can figure out loading photo I will do so. This is the first set of Hodaka forks I have taken apart, but not the first set of forks I have done. I have never come across this before. They both broke at the point the roll pin goes through the tube. Hopefully the files attach. D
BTW, anyone got more of these laying around than they will ever use? :D
Stever
Post by Stever »
Dennis, were the damper rod springs still there? Back in the day I think there was a popular mod for a while to remove them for a bit more travel, never did it myself.
Dennis D
Post by Dennis D »
Yep, all the parts are there. One thing I did notice when I pulled them out of the trees is that the tube would drop about a half inch before it would contact the upper spacer. Like the spring was too short. I thought this might be because of the broken tube and was going to recheck when I put them back together. D
