Dirt Squirt clutch spring specs
robbnc
Post by robbnc »
I'm trying to evaluate the condition of these 96 DS clutch springs and the only spec I can find is in the manual which is for Ace 90. The Ace 90 shows a 6 spring clutch vs a 7 spring clutch on the DS. According to the part numbers the two bikes have different springs. The DS uses #934011 and #934017. Does any know if the service limits are different on these springs? Also if need be does anyone have a source for the outer springs? Hodaka Parts has the inner springs but looks like they're out of stock on the outer springs. Thanks
Re: Dirt Squirt clutch spring specs
The Tech Spec sheets list the clutch spring lengths for each model. These can be found in the library section at Hodaka-parts.com. What is interesting is that even though the 96 Dirt Squirt uses the 93 Super Rat springs, the tech specs list differing lengths! Should get you in the ballpark I guess.
93 Super Rat Inner .67" (17.67mm) Outer .79" (20.79mm)
96 Dirt Squirt Inner 17.65mm Outer 17.27mm
robbnc
Post by robbnc »
Thanks! I didn't know the tech sheets were there! That outer 20mm spec is the one that had me worried, but it obviously doesn't apply.
