Help identifying pistons
[email protected]
Post by [email protected] »
This piston is 50.00mm
Re: Help identifying pistons
I'll give it a go. Single Dykes ring configuration suggests stock racing piston for a toaster tank Super Rat.
Are you measuring at the top of the piston? Check measurement at the bottom of the piston skirt. Piston is stamped 0.010" over-size - should measure very close to 50.25mm at bottom of skirt.
[email protected]
I did measure at the top. Thanks for your help
