Petcock
swartz14
Petcock
Post by swartz14 »
Anyone know how to repair the brass petcock on a model 94? I've tried lapping compound on the valve, which helped, but they sill leak.
Re: Petcock
Lap things for a couple more hours, then there are two ways to proceed (not necessarily in this order). 1. Assemble and install fuel petcock. Tighten the "cone" nut until the petcock is non- operational. Petcock should not be leaking. I hope you picked the position you want. 2. Use the glimmering, highly polished cone as a necklace pendant for your wife's Mother's Day gift. I've heard the now shiny interior of the valve body can be used to make teensy kaleidoscope. Seriously, I've never succeeded in re-furbing the brass petcock. Your mileage may vary.
Re: Petcock
Re: Petcock
Best answer yet, thanks Ed! :lol:
Re: Petcock
Love the answer, I thought I was the only one that failed. But we did have a banti rooster once. ------Clarence
Al Harpster
Re: Petcock
Post by Al Harpster »
I've done it, but it's a real time killer.
I'd say this:
If they are the originals you might have success IF you have various FINE grades of lapping compounds on hand. I'd say 400 grit & 600 grit.
AND you drive the little cone thing at maybe 50 to 100 rpm with maybe a low power portable drill.
Hand lapping may take way too long. I know I gave up. Or my fingers did.
I see Hodaka parts dot com has these aftermarket for $40. I have one of these and it is okay.
Buy one, plug the other side of the tank's outlet.
Re: Petcock
The Resonator Revisited has an article I submitted on the subject. I've had good luck with refurbishing the classic brass.
Re: Petcock
MTRat. Do you know the Issue of the Resonator?
Re: Petcock
Volume 2, Nr 26. There is a really nice Resonator subject index of back issues in the "Members Only" section of the club website. Very well done and helpful.
Al Harpster
Re: Petcock
Thanks Matt, never would have found it.
But I'd like more.
What's the gasket sealant that was or can be used?
Anybody know?
The later Strictly Hodaka after market ones were re-fitted with little tiny O-Rings in those grooves.
Re: Petcock
I've used Permatex Anaerobic Gasket Maker....
Re: Petcock
I’ve gotten rubber grommets from Terry which replace the fiber ones that used to be used. My Road Toad always leaked even with the valve turned off.
When Terry sent me the rubber ones they stopped leaking immediately!!! I just put a fresh fiber one on the Wombat Combat tank. If it continues to leak, I’ll go to Ace Hardware and look for rubber grommets the same size and see if it stops! :ugeek: Victor
Hosk1956
Re: Petcock
Post by Hosk1956 »
Not sure if you guys have them over there, but here in Australia I use a plastic tap from my local lawnmower repair shop, only a few dollars and work well, the downside is that they are plastic and you could break one off if you drop the bike.
I never have but carry a spare just in case.
Wayne from Oz
Re: Petcock
Wayne in Oz,
The plastic tap you use, does it screw into the tank bung like the original? If so, do you have a picture or manufacture name and part number?
