Air cleaner seal
Dennis D
Air cleaner seal
Post by Dennis D »
On the Wombat (94) air cleaner is the seal between the cover and the backing plate foam, an o'ring or quad ring? Thanks for any info, D
olddogs
Re: Air cleaner seal
Post by olddogs »
It is a narrow rubber c channel strip that fit over the outer edge of the backing plate. It becomes dried out and brittle over time so most did not survive.
Dennis D
Post by Dennis D »
Thank you olddogs. I can make one. My first Hodaka so I am full of questions!
olddogs
Post by olddogs »
I make my own out of rubber c channel sold as an edge protector for sheet metal products. It must be thin. The cover clearance is pretty tight. Put a light stretch into it while in place on the backing plate and use a piece of plastic wrap under the joint, I then connect the 2 ends together with a drop of super glue and later remove the plastic wrap. This keeps it from sticking and allows you to remove the gasket at a later date for painting or cleaning,
Dennis D
Post by Dennis D »
Olddogs, good news and bad news on the AC seal. Got some edging from Mcmaster-Carr and it worked like a champ. Bad news, hit the wrong amount in the quantity box and now probably have enough edging to seal all the airboxes in Hodaka nation. LOL! Thanks for the tip. D
olddogs
Post by olddogs »
Small business opportunity? I don't think anybody is reproducing them.
Dennis D
Post by Dennis D »
If someone needs some I would be glad to help them out. D
