Oil injection pump tubing
Can anyone recommend a suitable size/type of tubing to replace all the oil injection lines on an 01 DS.
Re: Oil injection pump tubing
Hodaka Parts, Inc.
Hodaka parts does show the lines available for order at around $8 each.
This is low pressure stuff.
Tygon tube on the inlet side would be fine.
Any automotive vacuum line that fits should be ok for inlet & outlet.
Just my two cents worth.
