Combat Wombat rebuild...
mikie798
Post by mikie798 »
Rebuilding a Combat Wombat motor - Haven’t done one of these in a while. The Left side crank shaft washer and Left side countershaft spacer are similar in size - which is which?
29.70 od
21.56 id
4.18 width
.32 side
28.85 od
22.09 id
4.06 width
.29 side
Thanks! Mike
Re: Combat Wombat rebuild...
I am going to rebuild a magneto in the next couple days. I will post the dimensions of the crank shaft washer for you. Not hoping to see the countershaft during this operation. :) Give me a couple days.
Those both are approx. the size of the crankshaft thrust washer. The countershaft thrust washer is around 36mm in outside diameter and approx. 22mm inside diameter. They both came in different thicknesses, 0.2 mm, 0.3mm and 0.5 mm.
