Correct Routing For Ace Clutch Cable
OK so I usually run it be Haines the left headlight bracket, between the down tubes and direct to the clutch cover. Is this correct, or is there a more original specs for routing locations? Thanks in advance!!! :ugeek: Victor
Re: Correct Routing For Ace Clutch Cable
As I remember it routes under the tank on the right side by the mounting bolt. Many people that restore have it wrong and the position of the shift lever also. ------------------Clarence
Thanks Clarence! :ugeek: Victor
