Engine Washers
Engine Washers
Hi and thanks for adding me! I've been reading this forum for the last 5 months but this is my first post, as I'm just now really getting started rebuilding my 96 DS engine. I've had the crank rebuilt along with a fresh bore and piston, many thanks to Dave and Terry. All new bearings and bushings are installed and I'm preparing to start reassembly. My question is this: does anyone have dimensions or descriptions of the various washers and thrust washers? I have searched but haven't had much luck. Thanks
Re: Engine Washers
Welcome aboard!
Here are some approximate measurements for thrust washers.
Crank left side OD 29mm ID 21mm .3mm thick
Countershaft bottom OD 32mm ID 19mm .35mm thick
Countershaft top OD 36mm ID 21mm .4mm thick
Kick starter shaft OD 25mm ID 16mm Come in various sizes .2, .3 and .5mm
Sorry, I don't have any notes on washers.
Re: Engine Washers
Most thrust washers are location specific so will only fit in one location correctly.
Re: Engine Washers
Thanks guys, that's exactly what I was looking for!
Re: Engine Washers
You can also see the washers & shims on the parts fiche on Terry’s website! Victor
