Wiring/ connectors
Wiring/ connectors
Best place to get correct connectors to build harnesses or repair dpo issues ?? Also what gauge wire is required?
Re: Wiring/ connectors
Scribbler
Post by Scribbler »
Harnesses are 18 gauge stranded.
Thrownchain, I suggest you contact fellow club member, Roger Karen in Utah, whom is building wiring harness,s for various models, he has a lot of info on wiring needed and parts and pieces needed to make things work correctly, His phone number is 1--435--994-0534, e-mail address; [email protected]. Tell him I sent you for info. I know he has had conversations with Terry about the same subject. Bruce Young
What I have are several ignition assemblies with cut wires that need to be returned to stock. If I could send them out to be done that would work, if not I can do it myself as long as I can get the correct parts.
Thrown. I use cycle terminal. They provide kits or you can order bulk. Up to you. The kits provide plenty of male & female bullet connectors and also some double & triple female connectors as well. And I use a needle nose to punch first and then wire stripper pliers to exact more force on the crimp location. They work very well! :ugeek: Victor
http://www.cycleterminal.com/bullet-terminals.html
