So far, I've tried WD40, PB Blaster, and a rust remover spray on product advertised on FB. None have worked.
Today I’m going to try acetone & ATF mixed 50/50. If that doesn’t work, I’ve ordered a product called CRC Knock’er Loose. I watched a video on YouTube where a mechanic cleaned an 8 cylinder engine with the Knock’er Loose right down to the bore marks on the cylinder walls with nothing more than Knock’er Loose and paper towels.
If the acetone/ATF don’t work, the Knock’er Loose will arrive on Thursday. I also have an Ace cylinder with a .080 piston which is seized up I will try it on. I bought a 13 oz. spray can on eBay for $12.62 tax included. I will report how the product works!
