ace 100 crankshaft flywheel die
What metric die would match the threads on the flywheel side of the crankshaft. ------Thanks Clarence
Re: ace 100 crankshaft flywheel die
You just trying to refresh the thread for the puller? I can get the specs off my puller tomorrow.
No the crank shaft, right side. Thanks ------Clarence
Flywheel is left, clutch is right.
Right side is also left hand thread ( backward)
According to the fiche it’s an M12. I’m thinking maybe a .8 mm thread? And left handed or counter clockwise tightening.
Well when I get old I should be able to make mistakes. The flywheel the flywheel, the Left side crankshaft threads. And you are all correct and I am wrong, the flywheel is on the left side. Thanks folks. And the answer is ? ------------------Clarence
10mmx 1.00
dumb question. What die for the early 125 wombat crankshaft, mag side?--------- Clarence
Same part number, so the same die.
Buy a metric thread file. If the threads aren't total destroyed it should work fine. Just use the correct size thread, there are 4 sizes on each end.
Sterling
Sterling
Looked this up just now.
https://www.acehardware.com/departments ... es/2367530
Good Luck,, sterling
Thank you very much! On my way, only 20 minutes away.-----Clarence
Got the job done?
