Can someone measure the dimension of the bolt pattern of the handlebar holder on a Model 92B or 94?
I need width apart ( left to right ) and spread of the bolts in the holder itself, ( center to center ). I'm trying to see if it's the same as a 250ED.
Thanks!
Handlebar holder width dimension!
1976 ED250
Re: Handlebar holder width dimension!
Model 92B has the following dimensions:
Width apart inner:2.25”
Width apart outer: 3.5”
Bolts center to center: 2.75”
Space between bolts on one side: 1 3/8”
Handlebar diameter is 7/8”
Hope that helps.
Hope that helps.
I did a quick check too and can confirm Victor's information. Bolt centers are 70mm apart side-to-side and 35mm fore-and-aft. I got those measurements on both a Dirt Squirt and my Wombat/Combat Wombat hybrid with Model 03 forks (which are the same as the 250 forks except for spring rate).
Thank you both for the quick accurate reply. The dimensions you gave match what I measured on my 250ED.
Enjoy Thanksgiving.
Enjoy Thanksgiving.
1976 ED250
Great! Glad tge Captain provided in mm to my inches! Happy Thanksgiving! Victor
