Road Toad Puddles
Road Toad Puddles
I’m guessing it’s my petcocks? Even with them turned off it appears to be leaking fuel. Is there a rebuild for the petcocks or just replacement? It just started leaking this week. Thx! Victor
Re: Road Toad Puddles
Go above the petcock and make sure the tank itself isn't leaking, the threaded area isn't leaking, then check the valve itself. Replacement is the best option, although there could be an argument about trying to overhaul.
If you were going to overhaul, where would you find the parts? Terry doesn’t seem to offer the intervals separately, does he? Victor
i to had leaks ,so being neither a perfectionist or a purest i went down to the local napa store and for under 15.00$ i got two shut off valves, Teflon tape, and a tap to match in a short time i had no leaks. worked for me...albert
I found a pair on eBay for $35. They’re already in the way! Victor
