Combat wombat reed valve
I was wondering if a model 97 reed valve will bolt on a model 95 combat wombat? Thanks DG
Re: Combat wombat reed valve
Nope. stud spacing is different. I have seen people ream out the holes and make it work.
Thanks DG
I have done that swap many times , But rather than reaming the holes out I remove the studs then drill out the threads and plug the holes with 1/4 aluminum rod and re drill for the correct witdh , call me if you want to know more about it 702-858-9177
Thanks for the info. DG
