Making sure I’m doing this correctly.
I purchased an aftermarket condenser as recommended in my thread about after market condensers.
The only difference is this condenser has a wire coming off the top instead of a soldering location.
So, if I tinned all the wires which normally solder to the top of the OEM condenser, and I solder them all to a stripped end of the wire from the top of the condenser, I should have the same connection, Correct? Victor
Condenser Connection
Re: Condenser Connection
That is correct - and you won't have any worries about over heating the condenser.
It’s a bit of a tight area to solder in, but I guess no more so than soldering on top of the old style condenser & no chance of having solder hit the outside of the condenser. Victor
Make sure you route the wire so it doesn't contact the rotor.
Already done that. Thx. Victor
Check the timing and check for spark.
