Hi guys I blew the top end on my 02 76 Road Toad on the Hodaka Days Poker run this year,
It was already bored 40 over, so I need a good used one!
Let me know if anyone knows where to I could get one? Thanks
Need 02 Road Toad Cylinder
Re: Need 02 Road Toad Cylinder
I would check with Bruce Young. He has some Toads from which I bought misc. parts. I would guess he has motor parts for either a Model 02, or a Model 99 which will also work.
Bruce can be reached at (208) 571-2823
If you need a piston, Toad pistons are scarce. But you can substitute a Super Rat piston & it will work. I have a Model 99 with a Super Rat piston in it right now!
1975 99 Road Toad 2
I have a good cylinder I would part with.
Two things.
1: They used to make pistons up to .080 over, you can still find some on ebay from time to time, so your cylinder could still be usable.
2: If the cylinder isn't too bad, you could see about having it plated and use a new piston that fits with the plating.
Just a couple of other ideas for you.
Check with Greg at California Hodaka. He may still have some pistons, maybe a larger one?
1975 99 Road Toad 2
Thanks Victor could you give me contact info on Greg at California Hodaka.
I would like to give him a call.
Ok got the info Thanks again
