Compatibility
1969ratfink
Compatibility
Post by 1969ratfink »
Can anyone tell me if the compatibility of the following part for my Hodaka? I own a 1971 Hodaka Ace 100B. The part number for the "fuel tank" is 909000 I would like to know if the fuel tank with the part number of 999000 will properly fit my bike, without modification. (I believe the 999000 off of a Road Toad is the same tank...but is painted green.) Can anyone give me some information? thanks 1969ratfink
Re: Compatibility
Nope, that isn't a "bolt on" compatible switch.
ANY of the "pillow" shape "toaster tanks" would interchange directly. NONE of the "coffin" painted tanks will interchange directly.
1969ratfink
Re: Compatibility
The tank I am looking at is the "pillow shaped" (not the toaster tank). It looks identical to the "original silver tank", but is painted green. So you think it would match-up and fit without any modifications? thanks 1969ratfink
Re: Compatibility
DOH! What was I thinking? Yes, the 99 Road Toad tank IS one of the "pillow" shaped tanks and will bolt on straight-away.
PS: Sorry for the mis-statement in the earlier response.
BrianZ
Re: Compatibility
Post by BrianZ »
Interestingly, the model 99 Toad tank will not fit an Ace 100. I just tried it, and the tunnel at the rear of the tank is too shallow. The Toad tank will fit a model 94 Wombat, but not the Ace (or model 93).
Re: Compatibility
Brian:
That's news to me -- but it is hard to discount an " I went to the garage and tried it" test. So I guess we have to go with the test information.
Are you sure that neither the tank nor the frame you tried it on have been modified?
BrianZ
Re: Compatibility
Post by BrianZ »
Ed;
Like you, I'm a little hesitant to accept something I'm told when it is contrary to what I already believe. I suppose we all are, and that's a "good thing", especially with the amount of misinformation easily available over the internet. I'll offer up some evidence in the form of some pictures:
I discovered this a couple of years back when I tried to fit a Toad tank to a 93 Rat frame.
Re: Compatibility
Brian:
Thanks for taking the time to shoot the photos. You have corrected/added to my knowledge base. Thank you.
admin
Site Admin
Re: Compatibility
Post by admin »
Thank you Brian I like Ed did not know this. I had thought a Toad tank would have fit the Ace frames.
Parts are on the way also!!
Thank you
paul
racerclam
Re: Compatibility
Post by racerclam »
I discoverd that also about 5 years ago when building my niclkel platet 1970 Rat and was installing my freshly powder coated 98 tank , so I lopped off the mounting tabs and re welded them to the correct position , pretty easy job to do if all you have to use is a later tank ,
tvrc18
Re: Compatibility
Post by tvrc18 »
That is a nice looking bike. Is that a Swenco front end and swing arm? Is it a 100cc?
Terry
racerclam
Re: Compatibility
Post by racerclam »
Thanks Terry, swing arm is swenco front end is Van Tech Engine has a Webco 125 kit reed valved
