Next, I hung the pipe from my garage door, and gave it 3 coats of the Enamel Ceramic High Heat engine paint.
After painting the pipe, I pulled off the air box. I needed to weld the lower portion of the bracket which holds the screw to bolt on the covers. Then I sanded off the rust and lightly sanded the old paint to give it some tooth for repaint, and shot the air box black again inside and out. My welding still isn’t retail quality but I’m improving.
I removed the zinc bracket from the back of the air box before painting, and while the paint dried, I cleaned the bracket with a brass wire brush on my drill. I also replaced the old 6mm nuts & lock washers with new ones as they were rusted badly.
Finally, I removed the mud apron from the frame and figured I would wash it clean & lightly paint over the old vinyl. But to my surprise, after removing the dried mud, the apron was in pretty good shape. So it’s just going back on clean.
That’s it for now. More to come as I move forward!
