Front brake lever needed. I'm hoping someone can help me out with purchasing a front brake lever. I'm not sure where to buy one. I believe the part no is 908901. This is for a 1976 Hodaka Road Toad 100.
Thanks for your help,
Mark K
Front Brake Lever - 1976 Hodaka 100 Road Toad
Re: Front Brake Lever - 1976 Hodaka 100 Road Toad
I'd be looking to replace the other cable in the pic also.
That's actually a clutch lever installed upside down, the cable slot should be on the bottom side. Try HPI.
Have you try any of the Hodaka Parts suppliers?
Or I think Honda levers match up with Hodaka.
If you’re going to replace one, you might as well replace both. Terry has them new & I bet Bruce Young has good used sets as well! Victor
