Clutch plates for ace 90
I think the plates on the right are from a ace90. Can anyone tell me what the discs on the left are from?
Re: Clutch plates for ace 90
Not sure about the one on the bottom right?? The fiber plates on the left are typical for Hodaka 100 and 125 clutches. The one on the bottom left is just an improved version of the one above it. I think they switched the design around 1975 or 76 with the introduction of the oil injected engines.
For clarity . . . the photos are turned 90 degrees to the left. So "right" = top
The "left" (bottom) clutch parts fit the larger clutch which started with the Wombat.
So he needs an Ace Clutch case to be accurate? Does it matter whether it’s an Ace 90 or 100? Are they the same size clutch case? I may have a spare I can send him to use for the rebuild.
Just as I figured. The D.P.O. switched out parts without staying original! Victor
If that is all she had she might be a SPO smart previous owner. I guess I am missing some pictures. ----------Clarence
