Rylan's pipe - Attn: Captain Eddie
Captain, could you take a look at the photos of Rylan's bike on the "shifter" and "exhaust" threads he has recently posted? I'm starting to wonder if he's fixing to mount a toaster tank Squirt pipe (PN 969161 vs 999161) on an 01 frame. I'm sure the pipe will work but he might need to do a little basic fabrication to mount the pipe. I'm looking particularly at the lower mounting tab on the pipe. It seems wayyyyeeee forward of its mounting point on the frame. The upper hanger looks a bit long too. I'm wondering if Rylan is mounting a M96 exhaust system and hardware on an 01 frame. Mayhaps you can save him some frustration.
Re: Rylan's pipe
Yup, that looks exactly like what is happening. A bit of home-brew fabricating is going to be needed.
Re: Rylan's pipe - Attn: Captain Eddie
I thought that might be the case. All part of the fun really. Thanks Captain.
RylanCoffey
Post by RylanCoffey »
I have 2 more exhaust pipes im gonna try before i modify the one in the picture. Thank you for the tips!
RylanCoffey
So the mounting point thats waaayyy forward, could i bend it down to make it work?
RylanCoffey
Im thinking to just put the lower bracket in a vice and carefully been it backwards closer to the frame side
There you go. It would probably be better to bend/modify a bracket than to bend/modify the pipe itself. If necessary, purchase a short length of (say) 1" wide by 1/8" (3/16"?) thick steel strap and make a bracket/strap from scratch.
RylanCoffey
Will do ! I havent been able to get around to the bike today. I will let you know what i get done!
