Identify Ace 90 parts
bobwhitman
Post by bobwhitman »
Attached (I hope) are some Ace90 bits which I need help identifying. The swing arm is shorter than the normal one next to it; the carb is a17mm spigot fit, the intake manifolds are the same is as a “Normal” 20mm carb (were they designed to accept a 20mm spigot carb?), and the main shaft on left has no splines.
I’ll try to post pix now, Clarence, Max, all you Vintage Experts lemme know!
Re: Identify Ace 90 parts
Bob, you have treasure of early Hodaka parts and pieces, I have some of the same carbs and manifolds and I am sure the swing arms, Call me need to talk to you about this Hodaka ACE 90 stuff you picked up and what you are going to do with extras, Bruce Young
I still have my spigot and carb, I thought it was a part of go fast, the only advantage would be quicker jet changing? The main shaft was the early one, Hodaka made a big change on #233 complete front end, headlight, rear fender, taillight, and got rid of the duck bill rear mudflap, I think it was the mach //. The handle bar holder was engraved in not raised. -------------------Clarence
