Extra frames
Extra frames
I have acquired several frames that I have no use for.
Ace 92 (spoken for)
Ace 92b (A-51329)
Road Toad 99 (H-18941)
250Sl 70 (N-04246)
All in good condition with swing arms.
If anyone is interested in any of these I can bring them to Hodaka Days.
Ace 92 (spoken for)
Ace 92b (A-51329)
250Sl 70 (N-04246)
Re: Extra frames
What is the frame number of the B+ ? --------------- Clarence
Re: Extra frames
Tether, can you give me a call, might want to talk about frames and what ever else you have. 1--208--571--2823 Bruce Young
Re: Extra frames
B+ frame
A 51329
A 51329
Re: Extra frames
That is a early 92B frame. The 92B started with frame number 51013. The 92B+ started with frame number 67613. ---------------Clarence
Re: Extra frames
Clarence,
According to this listing it is a B+ (line 12 on the chart) is this wrong?
Re: Extra frames
Line 12 is the beginning of the 92B, frame serial number A51013. Total number produced 9,900, Made in 1971
Line 20 is the beginning of the 92B+, frame serial number A67613. Total number produced 3,400, listed as new for sale in 1973. --------------Clarence
Re: Extra frames
I have a couple frames/ chassis i'd part with. 1 is Wombat, not sure on the other. I'll check 'em out tomorrow.
Re: Extra frames
So the chart is wrong then when it lists is as 92b+. This is the one I have been using to try to Learn the models and identify stuff.
Re: Extra frames
According to the chart I use, 92B starts with 38713, and B+ starts with 51013 ( A prefix)
Re: Extra frames
Thrown,
That’s what the chart above shows.
Re: Extra frames
I can't blow up the one you use. Mine was put together by Bruce Young. Even the "book" uses the same number references.
Re: Extra frames
The chart is wrong yes, by some numbers and some model dates. 90 + % good or better. Will follow up with suggested adjustments. ------------Clarence
Re: Extra frames
I know that Paul Shwarting has at least 4 extra frames, done with forks on them. For sure he has at least an Ace 90, ablue either Suoer Rat or Super Combat (didn’t look for frame numbers) a Road Toad Frame and I believe a Model 94 or 94A Wombat Frame. Paul has sold off nearly everything he had left. I’ve bought 4 bikes from Paul. Just passing the info on. He lives in Dolores, Colorado in the SW corner of the state. Victor
Re: Extra frames
Not to throw another wrench into the frame numbers issue, but the Owners Hand Book for the Ace 100 B+ (manual part # 929510C, the red cover manual...yes I have an original one) list the starting frame number for the Ace 100 B+ as A-63113.
Re: Extra frames
Thanks for helping! Is there anything in the book that identifies it as a 92B+? My data shows the 92B+ or 100B+ hand book/parts list, starts with frame #67613 and a manual number 929510D. I have the cover and am still looking for the manual with $$. --------------Clarence
Re: Extra frames
It doesn’t really matter to me but it is confusing.
I Edited the original post and removed the +
I will get the frame numbers and add those and let whoever might want them decide.
Thanks.
Thanks.
