Need Source for Sandwich Head Gaskets
Does anyone know a custom gasket builder that can do these sandwich copper plated head gaskets with impregnated fiber in between? Note the copper bottom came un-laminated from shipping but was a single piece off the motor. Tried Cal Stender and coppergaskets.us- neither can do. Thx in advance.
Re: Need Source for Sandwich Head Gaskets
So far it appears that I am not alone . . . I've got nuthin' for you on finding a custom gasket maker.
I don't think I've ever bumped into the type of gasket material you have described either - at least not in a two-stroke head gasket. (Which may just show my limited experience with other marques.) Ennnneywayeeeee, if you could find that type of material somewhere, it wouldn't be that hard to cut your own gasket. Good luck!
