Kick shaft wear ?
mac
Kick shaft wear ?
Post by mac »
It seems to me that it needs to be replaced,but thought I would ask in case it,s not as big of a deal as I think it is. I could smooth out the bad spots but it would leave a low spot. These two are the only bad spots.
Re: Kick shaft wear ?
The pins need to come out evenly, to me it is iron and I would junk it. The answer is to set up the engine so it will start and you will not have to kick it like a Harley 74. ----------------Clarence
mac
Post by mac »
10-4,thank you.
Clearly in need of replacement.
Contact Diane at [email protected] and get the heavy duty roller cage too.
