Countershaft sprocket--Ace 100B+
- cineburger
In searching for a 14T countershaft sprocket (042014) I came across a 934624 14T which to my uneducated eye seems the same; anybody know if this will interchange?? thanks, david
Re: Countershaft sprocket--Ace 100B+
Assuming you are searching on the Hodaka-Parts.com site? If so, I see that when you search by schematics that the 14T (042014) sprocket does not come up, but when you do a text search for "countershaft sprocket" it does show the 14T for the B+ with the 93xxx number. I am pretty sure that this is the correct sprocket for you as long as you are using a 420 chain. You might want to call Terry to confirm before ordering.
Yes. I had trouble finding countershaft sprockets on the home page but calling Terry got me there! Victor
