Hodaka Road Toad
Hodaka Road Toad
Hi, I'm new here, I just bought a 1977 Hodaka Road Toad in fair condition this morning . It has compression but no spark. Shouldn't be too hard to get running again. I'm looking for some parts (points, condenser, carb to air box boot and air filter). I'm also looking for a Hodaka service manual. Any help would be great!
My first dirt bike was a Hodaka Dirt Squirt!
- gearyoliver
- Contact:
Re: Hodaka Road Toad
I tried to order a boot last week. out of stock. I got one off eBay it had cracks but not torn throigh. I put half a dozen coats of some rubber adhesive letting tack dry between coats. Then I covered the whole boot with electrical tape. It should work until I get a new one. Maybe will work for you as well.
Black 3M weather strip adhesive works well and stays pliable.
I have taken some black RTV and used it to fill in the cracks. It has worked well for me even on air boots! Victor
Thanks, I’ve used the black RTV on boots before .
Are there wiring diagrams on the Road Toad out there?
If you look at the following topic Road Toad Lighting Issue from April 2, 2018, the second post has a wiring diagram.
I can shoot you a picture of the one in my book. Here it is! Victor
Let me know if you have any lighting/wiring questions. I’ve done 2 Road Toads in the past year & a half. Be glad to talk to you about any of the “funny things” in the Toad wiring! Victor
Also, I found this on eBay for ya! I’d grab it up quick! These are hard too find! Victor
https://m.ebay.com/itm/Hodaka-Road-Toad ... Sw~B1aPfoh
Thank you! Very helpful!
Anyone have the newest (last) version of the Hodaka service manual? I don’t need a original copy. Just a copy or pdf. I just need it for torque specs, clearances, and ignition values. Thanks
Dozerash, give us a call, 1--208--571--2823, we can help you with orgainal manuals and even some copy of same for diff models, Bruce Young Hodakapartsidaho.com
Hodakapartsidaho I’ll give you a call either later today or this weekend. Thanks
I got the Road Toad running yesterday! It ran pretty good for sitting for so long! It’s gots some power for a 100cc bike! I need to clean some rust in the tank clean the carb. Need to replace air boots, I can see daylight in the air box the boot is so dry rotted!
The clutch wouldn’t disengage until I rode it around for awhile. There is a little oil leak on the left side after running it a bit.
Let’s see the after pics! And maybe a link to a ride video! ; D Victor
