Main jet
Re: Main jet
You will probably have to contact Mikuni (or a distributer such as SUDCO) to find out if and which ones will work. Being different shapes, even if the numbers were the same the flow rates could be different. Best to check with the source.
Re: Main jet
guess i have to go thru them to to see what i got and go from there. thanks ...albert
Re: Main jet
There are several places on the web where you can go and ID Mikuni jets. Call me if you have a problem 1--208--571--2823 Bruce Young
