Ace exhaust threads
Ace exhaust threads
Anyone have a way to freshen the threads? I have a cylinder that the pipe and nut must have been loose and flattened the threads. Good cylinder other wise.
Re: Ace exhaust threads
Perhaps a metric thread file?
Here's one, probably other brands out there:
https://www.amazon.com/Allstar-Performa ... B003BZLK6O
Looking for a die or something along them lines. Thread file will take days to clean them up.
awwwww, I can't imagine it taking any more than 2 or 3 hours with a comfortable workspace, a NEW (sharp) small triangular file and the beverage of your choice to chase all the threads on the complete exhaust spigot, even with a LOT of flattening.
I would make sure it was a quality file. I would think cross threading rather than loose because, it would be leaking, noisy and running very lean. ----------------Clarence
I'm on board with the thread file, they've saved my bacon many a time over the years. Or you can make your own die by using an old (or new) exhaust nut, by making a few cuts vertically across the threads for the swarf to go. Might be a bit easier and cheaper than trying to track down a die.
Here's a few links I quickly found on the subject, there's more inspiration available online.
https://www.ehow.com/how_7734911_make-o ... hread.html
Same principle but with a bolt:
https://www.instructables.com/id/Make-a ... om-a-bolt/
I've used this a few times and really helps when its an odd size, pitch or thread count... i.e. Whitworth.
Bev
Bev
'72 Wombat (94)
'65 ACE 90? (Frame)
'66 Triumph Bonneville
'99 Triumph Adventurer
'66 Ace 90/100- Dirt only
'65 ACE 90? (Frame)
