Hello fellow Hodaka lovers.
I have misplaced my key to my Road Toad.
I will be ok with making the Toad a dedicated trail bike.
Can I bypass the key start?
Please if anyone has any advice that would be most appreciated!
Thanks everyone!
Dan
Lost Key!
Re: Lost Key!
You can get a replacement key from Paul that will work in any Hodaka ignition switch.
Tom
Tom
Re: Lost Key!
The ignition switch has a white connector that goes to the wiring harness. I'm pretty sure the bike will run if the white connector is unplugged. Just make sure that the kill switch works so you have a means to shut off the engine.
