new project
new project
well there starting to multiply. motors froze, tank and seat gone, and lots of other stuff gone. frame and engine numbers make it a 1971 b+ . just could not help myself.one good thing the dog house is not to cold this time of year.....albert
Re: new project
Fire damage on front wheel?
Re: new project
Sweet man , squirt some pb blast or wd40 in the sparkplug hole on top of piston and Rock her back and forth while shifting through all gears and see if u can unlock the motor, best of luck
Rylan
Rylan
Re: new project
If its Locked up cause of rust and water u should be able to unlock it with oil and some elbow grease , if its mechanical then obviously you will have to rebuild her which I hope is not the case
Re: new project
yes it was in a fire just the front tire and rim. got it in a package deal with a burned up 1975 harly 250 scrambler thats toast. there was some oil or something in the spark plug hole got the head off and some movement in the piston little heat tomorrow see what happens cant spend to much time on it have to keep working on the other one....albert
Re: new project
Sweet man I hope u can unlock it
