Crankcase oil ?
Dean Simms
Crankcase oil ?
Post by Dean Simms »
Hi all, I picked up some Bel ray gear saver 80wt oil that is recommended in the forum. I noticed there is also a Bel ray gear saver 80wt-90wt gear oil type for sale in strictly hodaka.Hoping I'm using the right oil.Thanks Dean
Re: Crankcase oil ?
Yes your good.
Re: Crankcase oil ?
Double check to make sure that you got the Gear Saver Transmission Oil and not the Gear Saver Hypoid Gear Oil. The bottles look the same but Hypoid Gear Oil is NOT recommended for wet clutches. Odds are if it is straight 80w it's the correct oil.
Dean Simms
Re: Crankcase oil ?
Looks like I got it right thanks for the response
Re: Crankcase oil ?
Case close everyone :D
