New Steen bike
New Steen bike
Just picked this up for my son.
Any way of dating it?
There's a number on the engine 120081 and on the front of the frame 6157321.
We're new to these, so any help/advice would be appreciated.
Re: New Steen bike
I'd say because of the Alsport /Steen on the tank it is a later model, early 70s? Motor is basically an Ace 100 motor, body work is available on ebay. They seem to be popping up on a regular basis so the build should be fun.
Re: New Steen bike
Thanks, I think the goal is to get it running and play with it a bit to see if he likes it before sinking too much money in it.
What kind of speed do these have?
Re: New Steen bike
Uh, the motor appears to be Fuji and not Hodaka. If so, Ace 100 parts are not going to work. You would need to source Fuji parts if required.
Nice find.
Nice find.
Re: New Steen bike
Ooops, my bad, gotta look at the pics harder before answering. I can refer you to a Fuji parts guy if you need it. Body work is still the same. That does explain the weird motor number. And if you want you can bolt a Hodaka Ace 100 in it if you so desire.
Re: New Steen bike
If you get it running well (which will probably take at least new engine seals as the old ones will probably be worn out/dried out) the bike will go anywhere from 30 mph up to 45-50 mph, depending on gearing, etc. I don't think I would want to go much faster than 30-40 on an older bike like that until it has been gone through. Worn bearings, tires and such could make it hard to ride safely.
Re: New Steen bike
FYI Hodaka-part Inc, Missouri has a lot of info on building these bike, they have regular business picking up machines and restoring them for the trails again, give them a call Ask for Terry Larson
Re: New Steen bike
Thanks for all the great info. I will let you know how we do. Hope to tinker with it next weekend.
