What is the difference in say Ace 100 plates and the 93 Super Rat plates? I noticed they have a different part number.
Terry
clutch plates
Re: clutch plates
there shouldnt be any difference, there is a difference between them and the later steel plates like the 125s and toads where the steel plates are cut different in the teeth where the fit the cage
Re: clutch plates
So the fiber plates should be the same for 100 and super rat?
Terry
Terry
Re: clutch plates
Correct. But you would do good buying the new ones from Paul they are much better, they arnt just fiber they are lined aluminum backed.
