Ace compatability 90 vs 100
Hi all, Will an early Ace 100 shift/mag cover (1 up/4 down shift pattern) be a direct bolt-on replacement for an Ace 90 motor? I recall 'yes'. Looking for confirmation. Many thanks!
Re: Ace compatability 90 vs 100
Is this a trick question?
Yes, I "think" the cover will bolt up, but the internals are different and not compatible. 5 speed vs 4 speed.
Holy smokes!! I just read my question. I can't even figure it out! Typing and talking on the phone at the same time is definitely not my strong suit. Let me try this again, Dale. Can I take an ACE 100 shift cover (1 up/5 down early Ace 100) and rebuild it to operate in a 1 up/4 down configuration using some Ace 90 parts I have in my stash? Whew! That's better. Sorry Dale.
That's pretty funny Matt. So, I don't know for sure but my guess would be yes. I am not where I can compare covers but I can in time and will get back to you on this unless someone else beats me to it.
racerclam
Post by racerclam »
sure , I put 5 speed guts in my 90 cover
racerclam
Post by racerclam »
sure I put 5 speed guts in my 90 cover for my webco 125 motor
Hey thanks fellas. I will see if I can put 4 speed guts in a 100 cover.
Let's see. I'm trying to remember all of this. I went the other way and put a CR 5 speed in my Ace 90. I did have to grind the stops on the case for more throw on the lever. Going the other way should work fine I would think.
I put a wide ratio in the 90 with a different 5 speed ratchet provided. I did not have to modify the shift cover. With the proper ratchet you would not have to modify the case for more throw ( I think), haven't played with it for years. I use the newer cover now because of the shift pattern but I still have the 90 five speed cover that is set up for five speeds. Clarence
TheBevman
Post by TheBevman »
On a related note, after reading this thread I was surprised to find that the '68 Ace 100 that my kids and I are rebuilding does indeed shift 1 up and 4 down. Quite the surprise! Looks like I need to REALLY look at the manual because I completely missed that fact. Now that I think about it and wonder if my kids will have some problems with it, they both currently ride bikes with "traditional" shift patterns, 1 down and 4 up.
Thinking along that line, my question is... What parts would I need to convert the 100 cover over to a traditional shift pattern (like my M94 Wombat)?
Looking at the Ace 100 and Wombat 125 parts breakdowns on StricktlyHodaka.com it looks like the foot change ratchet is the only part I can see that would need to change. Surely it couldn't be that easy swapping part # 912001-R for 942008 or on their respective schematics, #9-19 for #30. Could it? The part numbers for all other shifting components are the same save for those two.
Thanks.
Bev
'72 Wombat (94)
'65 ACE 90? (Frame)
'66 Triumph Bonneville
'99 Triumph Adventurer
'66 Ace 90/100- Dirt only
Unfortunately, it takes a swap of the cover itself to get the 1 down/ 4 up shift pattern. One that says HODAKA.
