Hi/Lo Beam Indicator
Question about this to someone who owns a Road Toad.
The hi beam indicator connects blue to blue at the location of the blue wire from the high beam switch. Also connected there is the blue for the speedo lamp.
It then shows yellow from the hi beam indicator to the yellow where the yellow from the headlight plugs in.
When I do this the hi beam indicator light works, but it stays on all the time. Is there something I should be doing differently? Curious to know. Thanks! Victor
