175/250 clutch
michael_perrett
175/250 clutch
Post by michael_perrett »
Need info on the 175/250 clutches. The primary gear is rivited onto the cage. Is this a direct attachment, or is there a shock absorbing system involved in the assembly? My assembly has a small amount of play in the unit.
Mike Perrett
rtboone
Re: 175/250 clutch
Post by rtboone »
I have a clutch for a 250 SL, and it has a small amount of play as well. About 1/32".
It feels like there are rubber dampers inside with no metal to metal contact.
The parts list does not show this part disassembled, so I'm assuming it is a cush drive.
Tom
michael_perrett
Re: 175/250 clutch
Thanks for checking that. I have an extra 175 clutch I checked. It has alot more play than what I am working with. Don't know the history of the loose one. The one I am working with has about the same amount of play as yours.
Mike
racerclam
Re: 175/250 clutch
Post by racerclam »
Yes its a primary cushion , just like the cushion gear available for the 97 and 98
racerclam
Re: 175/250 clutch
Post by racerclam »
Yes its a primary cushion just like whats available for the 97 and 98
