Pipe restoration
SuperRat01
Pipe restoration
Post by SuperRat01 »
Have anyone of y'all had your pipes restored at "Fusion One" pipe restorations? Linc
Re: Pipe restoration
Post by Hydraulic Jack »
Nope. Never heard of them until you mentioned the name. Looked at the website and their before and after photos. I suppose if you have a pipe that was smashed flat, their service might make sense. Minor dings don't really change the exhaust much, so I guess it depends on what you need to have done. They are using air pressure and localized heat to raise dents. I didn't see evidence of taking a pipe apart and truing a damaged cone or pipe, so the results vary a lot. Do you have a pipe in need of repair?
I used these guys to fix a model 98 pipe. They did good just took awhile.
SuperRat01
Yes, I do have a pipe with a couple linear dings that I need fixed. It's the last thing I need for my Super Rat (98) restoration. My concern is purely the cosmetic aspect. I plan on showing this bike. It has been difficult to find someone interested in fixing it. Linc
