ok i know i keep bugging you about this so here is last run down that i didBullfrog wrote:Your comment about it not doing the same blubber at 1/2 throttle in any gear except 2nd probably comes from the fact that the engine is not really "pulling" at steady 1/2 throttle in 2nd (and you just won't leave it at half throttle in 1st - note that I wouldn't either). Anyway, jetting is supposed to be checked with the engine "loaded" (made to work, not just "wind-mill"). So I think it is a good sign that it doesn't blubber in the higher gears - ASSUMING that you "found" the carb setting which DID blubber in the higher gears, then went ONE step leaner to arrive where you are now.
I kind of like the look of the plug. It MIGHT be showing slightly rich, which is what I sure as heck would want on a bike I'm just getting used to. But PLEASE don't do your jetting based on plug observations, OK? Take some time. Ride the machine. Carry a couple of spare plugs. If you find your jetting is indeed on the rich side and it is causing you problems with rideability or spark plug life . . . figure out what throttle position is rich and tweak that. Make ONLY one adjustment at a time, so you can gauge the effect of that ONE change - BEFORE making any other change.
By the way, what brand and heat range of plug is shown in the most recent photo?
How does a 200 main jet run at full throttle?
fresh plug b8 hs note i did swap new plugs in during test after jet changes
93 gas mixed 28/1 amsoil
pilot jet is done and staying with 40 1 1/2- 1 3/4 turn seems good
ran with 210 jet sputters at wot
ran with 200 some times sputters depending on gear/load but fine most of time
190 jet runs great seems like better power at wot but after a few wot runs plug has little sign of ash/gray
so i dont know if i should play it safe and run 200 or is the 190 best.
looking to get best advise from you since you have the expert advice
thanks for the help and patience with me
