Shifter Grease - How Much and Type?? Model 98
After painting the bottom end, I'm ready to put the side cases back on. I had cleaned out all of the old grease around the shifter mechanism, but don't know what type or how much new grease to put back in. Neither the Clymer or owners manual says anything about it, only bits and pieces that I've picked up by reading through these forums. Thanks. JackM
Re: Shifter Grease - How Much and Type?? Model 98
I use a good moly grease! The more the better! Victor
I use Bel-Ray waterproof grease for a lot of things. Would that work, and to what level? It is a messy job, cleaning the old grease out. I just want to make sure I get the right amount back in. Another messy job.
Some folks pack in all that will go. I don't. The grease is there to lubricate the mechanism, not exclude water or dirt. On a dirt bike, servicing the shifter case is regular maintenance, but removing a half pound of grease is impossible without solvent and lots of time. Use good grease, but consider it a short term lubricant, and clean it often throughout the year, especially after water crossings or between races. On a street bike, it can easily go all year on a dab of lube, or shoot a stoke or two with a grease gun into the nipple every six months. You can always take the small cover off and take a peek. If it looks grodie, clean it and re-grease. Packing the case full of grease will not make it shift better, and just makes a mess.
Packing the shifter cavity with grease is only recommended for those involved with riding in extreme coditions - such as what might be found during a wet Enduro or cross country event. Or for extreme trail riders. Though some do use the technique when racing mx on severe mud tracks. If that sort of use is in your plans, then use a"heavy" water-proof (resistant?) grease - and pack the cavity full to just below the control shaft location. I used the technique when competing in ISDT Qualifier events in the 1970's - which often involved 170-200 miles a day for two days in EXTREME conditions. I still pack the shifter cavity with grease on my custom Observed Trials bike. Severe mud conditions are sometimes encountered in Trials events. As mentioned, the technique is very messy with little or no benefit for a road machine or occasional, fair-weather trail rider.
