A Toad with OHMS
michael_perrett
A Toad with OHMS
Post by michael_perrett »
Is there any data on the ohms rating for the 99 Toad magneto ignition coil?
Mike Perrett
jakecb420
Re: A Toad with OHMS
Post by jakecb420 »
I don't think I like where this is going!!!!
Mike, don't forget I have the parts toad, I'm sure it has a coil on it still.
Mike, the Toad exciter coil should be the same as a Wombat (94) - and the specs are in the Official Workshop Manual.
michael_perrett
I do not have the workshop manual for the 94. Wish I did.
Get the manual! Its really the only one available which isn't just an owner's manual. Worth every penny! :D Victor
. . . and I can't get to my copy of the Manual right now, so I can't post the specs. Sorry 'bout that.
Regarding the exciting coil, per the Wombat Workshop Manual, resistance from end to end of the coil winding wire should be 2 to 2.5 ohms +/- 10%. Resistance from any point of the wire to the core should be infinite. In other words, if there is any current passage from the wire to the core, this condition denotes a "short to core" and the coil is defective.
michael_perrett
Mine tests at 2.5 ohms.
Mike Perrett
. . . does not "short" to the coil core? If that is true, you should be good to go.
